The latest beta thread (2)
Re: The latest beta thread (2)
@theoneofgod: can you send me one of your flv files?
@Paul: So, you really have the lag issue on every media files... I personally tested on WinXP 32-bit, WinVista 32-bit, Win7 64-bit and Win8.1 64-bit.
The L2 cache won't work properly on Win8 because this version of Windows has a nasty bug. I'll do some tests later on Win8.1u1 64-bit, but I'm quite busy currently with my professional and personal life (Media Preview has become a side project of mine). In the meantime, you can re-install the last official version (1.4.3), go to the Wizard of the conf tool and set Media Preview to "speed".
theoneofgod
Maybe it's not the file format. I have a folder of 200 files, mixed .mp4 and .flv, and MP is taking about 5 minutes to sort it all out.
Hello
Windows 7 = NO LAG
Windows 8 = NO LAG
Windows 8.1 = NO LAG
Windows 8.1 Update 1 = LAG
Confirmed after virtualizing each of them.
So Update 1 introduces some changes that make Media Preview work slow as hell. That's my experience. Probably explorer.exe has changed too much with Update 1. We will have to wait for Babelsoft to try Update 1 and release a new beta or just live with the lag.
Thanx!
Paul
Windows 7 = NO LAG
Windows 8 = NO LAG
Thanx!
Paul
theoneofgod
I can confirm I'm running Windows 8.1 Update 1.
Thanks to you Paul for going all the way to test in several virtual machines. At least, it matches my testing results. So, I'll focus on Win8.1u1 and see what can be wrong.
I suppose that theoneofgod has begun to see the lag issue only after upgrading to Win8.1u1 and this with his most recently acquired media files, which happens to be only .flv files.
theoneofgod
I've noticed it since you added the L2 cache. Maybe it existed before, I'm not sure.
Hello
Today I tried updating the libav codec dlls on the Media Preview folders (both x86 a x64) with latest versions from http://ffmpeg.zeranoe.com and http://libav.org but no luck with the lag.
Paul
Paul
theoneofgod
Code: Select all
General
Format : Matroska
Format version : Version 4 / Version 2
File size : 927 MiB
Duration : 1h 57mn
Overall bit rate : 1 099 Kbps
Encoded date : UTC 2014-07-26 08:44:09
Writing application : mkvmerge v6.9.1 ('Blue Panther') 32bit built on Apr 18 2014 18:15:44
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 57mn
Nominal bit rate : 1 041 Kbps
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.063
Title : KhaTTaK
Writing library : x264 core 133 r2334 a3ac64b
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1041 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=20000 / vbv_bufsize=25000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Codec ID : A_AAC
Duration : 1h 57mn
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz / 22.05 KHz
Compression mode : Lossy
Delay relative to video : 33ms
Title : KhaTTaK
Language : English
Default : Yes
Forced : NoRe: The latest beta thread (2)
@theoneofgod: is there any way for you to send me the mkv file responsible of the COM error? For this kind of errors, file properties are hardly enough to understand what's go wrong with a file. Having the actual file is usually the only way to find out what's wrong.
theoneofgod
Sure. Sent you a private message with the link.
